servo or dc stepper motor
Hi everyone. I am new to this forum. I am trying to control two motors which will position a telescope. I am not sure if I should use a servo or a dc stepper motor. The bs2 can handle both, but i need the motors to do the following:
1. Rotate 360 deg.
2. Rotate in reverse direction.
3. Have some kind of an encoder to determine the motor position.
Also, I will be having 8 inputs and 1 output apart from the 2 motors. The stepper motor has more wires and the bs2 can only handle 16 I/O, if a stepper motor is a better choice for this project, how can I use less pins to control them.
Thank You
1. Rotate 360 deg.
Thank You
More than you probably want to know about stepper motors:
···· http://stepper-motors.globalspec.com/
···· http://stepper-motors.globalspec.com/directory/Motion_Controls/Motors/Stepper_Motors
Don Buczynski
http://www.buczynski.com
·This does not leave place for my LCD connection. What do you suggest for that?
·Also, if the reset is activated on the allegro, will this move the motor to its initial position?
Thanx agian for the help.
Lee
Thanx.
