Are my calculations correct?
I will be driving a SSR via a transistor.· I would like to make sure my math is correct when picking the resistor between the pin and the base so I can limit the amount of juice the stamp·will be sourcing.· I'll be running about 8 instances of this setup at a time, so I want to be nice to my battery.
Data:
SSR:·[url=mailto:3.4mA@5]3.4mA@5[/url] Vdc
2N2222: .6 Vdc Base-Emitter sat. voltage
············approximating ~ 0.02 mA base current (from collector sat chart)
For the 2N2222, I believe the math should be
(5v-.6v)···· =··· .0002 A
···· R
4.4v····· = .0002 A
· R
R· =·22000 = 22K·ohms
Is·22K correct?·
Data:
···· R
4.4v····· = .0002 A
· R
Is·22K correct?·
Jon Williams
Dallas, TX· USA
Dave
Dave
It is a Serial controlled 8 channel SPST switch and can operate continuously at ±4.5V to ±20V·with a sink of 30ma/pin. I have a few in my parts box and havent gotten around to trying them out. Perhaps a simpler option is a serial to parallel shift register? The ones I have on hand 74HC164 can sink 25ma/pin.
Jon
Post Edited (Jonb) : 1/21/2005 3:06:31 AM GMT
Thanks!
