Video multiplexer - BS2
··· I would like to use the BS2 for a project I am going to attempt but am not sure it can do what I want it to. I would like to switch video with it. I want to take three different video signals, put them each on a different I/O,· select them with some sort of binary code on three other I/O's, and then bring one of the videos out on another I/O (according to the one I select). Something like a video multiplexer 3:1. Would the BS2 be capable of this (passing the video) from one I/O to another. What would the on resistance be between the two I/O's? Would it make the video noisy? Hopefully you can assist me.
JB
I hope that made sense (if you can't tell, Im a newbie to the stamp world)
JB
Take a look at what Maxim has of chips:
http://www.maxim-ic.com/SwitchMux.cfm
Jon Williams
Dallas, TX· USA
"...and then bring one of the videos out on another I/O (according to the one I select). Something like a video multiplexer 3:1. Would the BS2 be capable of this (passing the video) from one I/O to another."
Are you wanting to know if you can send in a video signal to pin X and get it out on pin Y? The answer to that is no. If you are wanting to know if you can control a peripheral video switch with the BS2 (and have video run through the switch, and not the BS2), then the answer is yes.
Dave
It's basically a big voltmeter! that assigns a 1 or 0 to a given threshold.· But it also has timing built in to aid in other measurements!
You can use the stamp as a controller but not as the actual switch or mixer.
You could use the stamp to trigger a relay which might have your video signal on it.· Now, relays are noisy beasts which would cause your video to go crappy for an instant....but setting up a switch board of relays is doable for your 3P3T needs.
Steve
http://members.rogers.com/steve.brady
