Scaling values
Hello,
I'm getting a value varying from 0 to 180...and i need to get it to correspond to 1100 to 120...
0 must correspond to 1100...
according to this link:
http://forums.parallax.com/showthread.php?p=519918
Using the above method i can get 0 to 180 to correspond to 120 -1100,but how do i do it the opposite way
ie 0-180 to 1100 to 120
Thank you for your time
**·ice**
Gerard Sequeira
Machinegrid.com·:: Robots at Work!!
Parallel Port Tutorials,
Autonomous Robots,
PIC16F84a Temperature Controller
Jon Williams said...
Since you're getting 0 - 255 now (I don't have a part to test so I will have to go with your assertion -- though it doesn't match the data sheet), you can use a simple equation to get your desired output range from the pot's span.
You want 0 - 255 to become 330 to 1230 ... so try this mx+b equation:
adc = adc */ $388 + 330
How does it work? Well, your output range has a span of 900, so you divide that by 255 (max pot value)·to get the slope (3.5294 -- the 'm' in mx + b). We can use the */ operator to multiply by fractions (in increments of 1/256). To use */ you take your fractional value (3.5294) and multiply it by 256; you 903.5 -- round up to 904.· I like to convert to HEX as I can see the whole part in the upper byte, the fractional part in the lower byte.· 904 in hex is $388.· Of course, we have to add the minimum value; then we're done.
**·ice**
Gerard Sequeira
Autonomous Robots,
That's not to say one of the guys doesn't have a good idea.
BUT, what type of sensor is it?· Might it be possible to rearrange a circuit (if it's a passive type of device?!).
You might try an inverting op-amp with a DC boost at the end?!
Steve
http://members.rogers.com/steve.brady
Jon Williams
Dallas, TX· USA
How would the stamp handle the sign....or does it matter?· 180 - 0 = -180.
Steve
The new equation becomes:· scaleVal = ((180 - inputVal) */ $571) + 120
The equation assumes that inputVal never exceeds 180.
Jon Williams
Dallas, TX· USA
Post Edited (Jon Williams) : 1/20/2005 2:42:34 PM GMT
Apparently I pressed too hard when I shaved my head this morning...must've taken some brain cells with it!
Steve
