where to start — Parallax Forums
where to start
rookierookie Posts: 2
edited 2005-02-06 18:47 in General Discussion
hey i'm new to the sx28 chip and could use any help i can get. To start i was wondering if you had any good sites to gain basic knowledge of the chip and the code for itconfused.gifconfused.gifconfused.gif
    edited 2005-01-19 18:48
    Depends on your programming experience, if your an experienced assembly programmer, you can get by on Parallax's online documentation: http://www.parallax.com/sx/downloads.asp·the SX User's manual contains nearly all information a seasoned asm programmer needs to get up and running.
    If you have programming experience in another language (BASIC, C what-have-you) I strongly recommend Guenther Daubach's Programming the SX Microcontroller: A Complete Guide http://www.parallax.com/detail.asp?product_id=70002
    If you have little or no programming experience I suggest Al Williams Beginning Assembly Language for the SX Microcontroller http://www.parallax.com/detail.asp?product_id=70014
    This is assuming your trying to program in assembly, If your goal is to program in BASIC look at http://www.parallax.com/dl/docs/books/ExploringTheSx.pdf·which is the newer version of Al Williams book which covers programming the SX in assembly and also SX/B (SX's version of BASIC). This is available for download free in its entirety
    Paul
    Post Edited (Paul Baker) : 1/19/2005 6:51:12 PM GMT
    edited 2005-01-19 19:00
    Rookie,
    How about the SX/B free BASIC compiler examples in the on-line help file for the SX-Key software. This resource is really well-designed to help you get started with the example projects. I'm not an assembly programmer, but with SX/B I understand the SX design much better than I have in the past.
    Ken
  • James NewtonJames Newton Posts: 329
    edited 2005-01-20 23:31
    http://www.sxlist.com/begin·Is another possible starting place.
    James Newton, Host of SXList.com
    james@sxlist.com 1-619-652-0593 fax:1-208-279-8767
    SX FAQ / Code / Tutorials / Documentation:
    http://www.sxlist.com Pick faster!
  • rookierookie Posts: 2
    edited 2005-02-05 13:29
    Tanxs lads for the help!!smilewinkgrin.gif· Just alot of work ahead of me. See i only have a basic knowlegde in java,C and ASm language for 8051 now have a mini serial terminal project to do using the sx28. See using the hyperterminal packetage i must be able to display a meesage on an external powertip lcd.
    I have the board built using rs232 to control voltage level in thsx28 chip . Seems pretty alright. I have it displaying mesages now all i need to do is get it to communicate to the port on the computer. Any tips·· rolleyes.gif
  • Jim PalmerJim Palmer Posts: 23
    Ken,
    I've had great luck with the Virtual Peripherals provided on the Parallax site: www.parallax.com/sx/downloads.asp
    I would recommend looking for the ones that reference "UART" and find the simplest one that meets your needs. I ended up using one that was in a source file called "uart_vp.src" originally written by Bruce Wilson of Scenix.
    You probably don't need this tip, but the only trouble I had in getting it to work was remembering that I not only needed the TX and RX pins, but also the common ground!!! [noparse]:D[/noparse]
    Good Luck,
    Jim
