Fried Stamp?
I think I might have fried my stamp. I've put together a carrier board. One night I managed to actually get the editor to pick it up, and I downloaded some code to it. Then when I attempted the next time, pc would not detect the stamp. Loopback: Yes Echo: No.
I am using a 7.5v wall wart and put together my own serial cable, including the .1u caps.
The only thing I have not tried is connecting a 5 volt power supply to the other power supply pin. The + of the wall wart is on pin 24 btw.
How will I know for sure if the stamp is dead?
Johnny
Post Edited (Jonathan Allison) : 1/19/2005 2:59:58 PM GMT
Johnny
Johnny
Jon Williams
Dallas, TX· USA
Whats this I hear about the parallax repair options? Is this chip a contestant for that? And whats the cost?
Johnny
FWIW ... I cringe every time I see someone say they're going to save a few bucks building their own programming boad, because about half the time things turn out tragically.· What you did is connect 6 volts to a pin designed for no more than 5 (my guess is that you destroyed the onboard regulator and that's what's getting hot -- hopefully the damage stopped there).· If you're going to build your own board and you want to use the Vdd pin, YOU MUST supply regulated 5 volts (as we do on our boards).· If you're going to use anything greater (6 to 12 volts), then that must be connected to the Vin pin.
Jon Williams
Dallas, TX· USA
Post Edited (Jon Williams) : 1/20/2005 4:32:24 PM GMT
Johnny
Jon Williams
Dallas, TX· USA
Johnny
