Ideas????
AIGHT YALL,http://forums.parallax.com/forums/emoticons/freaked.gif
freaked
I purchased a parallax boe bot with the board of education on recomendation from the inventor of the oobot 40-II. The class project is to get 8 billiards balls into the 4 seperate canisters of a pool like table. Any ideas on how to get it to push the balls in there? Any ideas on how to get the robot to know where it is on the surface of the table? All ideas would be apprciated. THANKS MUCH.
MEEEE
PS> HERE IS THE TABLE AND ALOT OF OTHER STUFF. THANKS A MILLION!
http://www.soinc.org/robobill/images/setup.1.gif
THANKS
freaked
MEEEE
THANKS
=·Front =
And if you add an arm which goes above and past the ball, to hook it in place you can even back up without losing the ball.
=·Fr!nt =
As for knowing where you are, I suggest calculating it by using starting position and adding the moves.
Just remember that you need to calculate it for a fixed point(Usually the exact center)·on the robot, then take the rest of the robot into account when dealing with walls.
Position location using an 8-bit microcontroller can be a very tricky business (at least on the small-scale....at least if you don't have to be any more accurate than 10 feet or so you can use GPS...but on a pool table....).
Some ideas to consider:
RF beacons
IR beacons
CMU cam on a servo and "colored cards" for beacons.
If you note the "beacon" trend, it's because any kind of dead reckoning will be strongly affected by "slippage" due to sudden changes of inertia versus the coefficient of friction (i.e. bumping into a ball), unless your 'bot is quite heavy.
It's an "interesting" problem...
XYZZY...PLUGH...*poof*
AND YES THEY CAN BE REMOTE CONROLLED....JUST WANTED A CHALLENGE
A CHAIN IS ONLY AS STRONG AS ITS WEAKEST LINK
GENIUS IS 99% INSPIRATION AND 1% PERSPIRATION
THERE IS ALWAYS GOING TO BE ONE PERSON RICHER THAN YOU, UNLESS YOUR NAME IS BILL GATES
Would i have to get another ir reciever for the beacon?
The only limitation is that the lasers must be class 3 and some thing must be done to protect the general public..
FYI, the quote from Thomas Edison is:
"Genius is one per cent inspiration and ninety-nine per cent perspiration. "
No matter how great the thought, it takes a lot of work to get results.
Jim
Ideas?
Thanks again
GENIUS IS 1% INSPIRATION AND 99% PERSPIRATION
