( Short Exposure ) CCD Camera
What I'm trying to build: a B/W camera system to take a snapshot of a very fast (250mph maximum) projectile.·The camera will be approximately 6-12 inches away from the projectile.
www.ovt.com mentions the following (which is great):
. I'm mostly concerned with exposure time, since I need as little blur as possible.
Can someone point me in the direction of what to look for in the datasheets, as well as other cameras to look at?
Any and all help/comments appreciated.
-noobie
Some datasheets are here:http://www.ovt.com/p_cameraChips.html·but I don't quite understand how to read themwww.ovt.com said...
To better suit the intended application, we normally allow the user control over how fast the exposure and gain algorithms work in the chip.
-noobie
but I thought exposure time was the amount of time spent reading an image....so, the old film cameras with their 600exposure times etc...
I think you want a combination of frame rates and a certain exposure.· The faster the frame rate the lower the exposure, and vice versa.
Someone can correct me on this!
Steve
http://members.rogers.com/steve.brady
So, another question... is CCD sensitivity basically the "film speed"?
Edit: Thanks for the quick reply!
nate
I've seen them in Radioshack for $30Can.
I picked one up and it's from DIGIGR8.· They're only 100Kpixels....but this will get you going with some cheap experimenting.
If you can find a copy of dec2004 Nutz&voltz, there's a guy that hacked one of these and put a small 555 pulse trigger connect to the shutter button on this camera.· He mounted it in his R/C airplane and took some aerial pics.
Issue there was that he had to set the 555 timer wide enough in pulsewidths so that the camera didn't go through all it's pictures before he got up!· (this one only has 26pics but runs on one AAA battery).
Steve
First of all, the link I posted, is for CMOS cameras, which I’m afraid are too slow to suit my purpose (too noisy as well). Second, I’m trying to create a digital system from head to toe, with no hand-tooling necessary. So, an old school camera won’t work (thanks for the suggestion though).
From what I’ve read so far (data sheets, product briefs, and explanations from across the web), most CCDs are fairly sensitive to infrared. This should help solve part of my problem, lighting, since I can create an IR strobe very easily. However, I can’t leave the CCD open because there will be ambient light in the environment(s) I’ll be shooting in. Like several of you have suggested, precisely controlling the strobe and shutter, is key to the crisp image capture I’m looking for.
So, the current prototype idea contains the following:
··· a) ·NTSC to VGA CCD w/lens
··· b) ·High speed CCD decoder/digitizer
··· c) ·LCD plane shutter
··· d) ·A fairly fast MCU (possibly a dedicated ccd controller)
··· e) ·Supporting ics, buffers, etc.
··· f) ·A ton of time
Here’s a hint… the projectile I’m trying to capture typically doesn’t travel more than 1000feet, and it spins a considerable amount (for some people, a lot more than others
If any of the assumptions I've made are wrong, please correct me!!!
Doing some quick trig calculations, assuming your equivalent format is 35mm (all but expensive digital SLR·CCDs are less than this, a smaller format=worse), the object is 12 inches away, and your depth of field is 1 inch (this is the range that is in focus, hence you object must be between 11.5" and 12.5") yeilds an angle of 90 degrees, meaning the path of your projectile within the field of view is 17". Traveling at 250mph and assuming the projectile is 0 dimensional (it has no width or height) it will be in the cameras sight less than 1/4000th of a second and this is the time it takes to travel the entire distance of the frame. An exposure of 1/40,000th of a second will make the projectile appear to be 1.7" long and this is for a 0" long object (a 1/2" object will appear as an object over 2" long). The LCD shutter I worked with was 35mm format and the fastest I could operate it was 1/100th of a second, a smaller shutter would be faster but it would also reduce the travel length of 17", and remember this is assuming your using a professional grade CCD (most consumer 2MPixel CCDs are 25mm or less). The cheapy pen cams will have a CCD around 10mm-15mm.
Im not saying its impossible, but you may need to approach the problem differently, a properly designed high speed synchro-flash can have illumination durations of 1/100,000th of a second, but to buy such an item is mucho-dinaro. You may be able to design an arc discharge lamp for a fraction of the price.
Paul
You maybe able to get some better figures by using an LCD that is mounted next to the lens (and hence is the size of the smaller lens not the CCD), the one I used was mounted to the format (the 35mm slide). I was able to get better than 1/100th of a second exposurse by combining the mechanical iris with the LCD where the LCD was clear, the iris opened, then the LCD went black but I still couldn't get 1/1000th of a second with·ISO-2000 and the picture have anything but dim shadows. Of course this was with physical film,·but CCDs have an equivalent ISO rating they are optimized for and·my·Minolta A2 only goes to ISO-800 and·I have problems with graininess·in the photos,·of course in such situations as standard·photography I am going to have·a higher standard of whats acceptable.
One final note, depending on your application it may be possible to skirt some of the issues, say if your just trying to measure the speed of the object, measuring·the projectile's streak duration (the time when you first register its presence till the time you last register its presence) may ease some of your timing constraints.
Post Edited (Paul Baker) : 1/20/2005 7:00:44 AM GMT
By my calculation, the optimal distance the projectile would travel in the area I have to work with was ~1/20th of an inch, which equates to something around a·.00001s·time interval. Obviously, extremely difficult, but more likely impossible·to achieve with a single-stage shutter of any type. Even with a dual stage shutter, I think the tolerances will be too high to achieve the timing accuracy I want.
Even with an arc-discharge setup, I still could·face a problem with ambient light... Maybe a pulsed IR diode setup would be sufficient... EDIT2: Actually, an IR strobe might be perfect for my application. I know for a fact they are reliable up to 50khz, maybe I can pulse an LED "Lamp" quickly enough to get a clear picture...
There's probably something I can do to deal with the [noparse][[/noparse]remaining] blur in·software. Also,·adding another camera in a different axis might help too. I don't need beatiful images, just ones I can analyze efficiently.
Ah the gears are turning!
Thanks again for your reply.·Keep em coming!
EDIT: The main reason I need·a clear image, is to track rotation. Haha, quite the "project", isn't it?
- Hatter -
Post Edited (hatter) : 1/20/2005 7:36:42 AM GMT
See that freeze 3D motion thing they do?
They use a matrix of cameras setup and they take a picture all at the same time and splice each image in to the film so it looks like it's real-life freezing.· cool stuff.
Well, are you stuck using one camera?· Why not set up 4 or more!
This way you could do some quick trigger toggling!
Fire them like your spark plugs fire!
1, 2, 1, 3, 2, 4, 3, 4· or some such order to overlap enough!
(and no, your plugs don't fire in that order! haha)
Steve
Paul
Ive seen the staggered photo effect, but know little about it. So I have no idea if it would help, this approach would also require some hefty post processing time to stitch the photos together, especially if you have a real-time constraint. I do know that its difficult to compensate photo blur in post-processing, I've spent many hours in photoshop trying to recover a blurry photo with limited success, of course I only had one perspective to work with.
Post Edited (Paul Baker) : 1/20/2005 5:07:35 PM GMT
nate
Paul
Though if Nate's assertion that this is for golf is true, doing this for a spherical projectile would complicate this method beause the projectile will be rotating on two seperate axis, the hook/slice rotation and the run/roll-back rotation.
Post Edited (Paul Baker) : 1/20/2005 5:30:18 PM GMT
In some form of digital tv transmission (HDtv or something) they only transmit the pixels that have changed!· So, you transmit your background less often than the moving foreground (it's a 'swimming' kind of affect...not nice).
You could overexpose your image and leave the shutter open longer (depending on camera type)....hard to say if this would help or hinder.
as far as the camera 'array' goes....you'd have a bunch of stills that could just be viewed one after the other.· Do you need to have them in a movie sequence?· All movie cameras are just cascaded stills that give the perception of movement....what do they call that....visual perception or something?·
Steve
Post Edited (Paul Baker) : 1/20/2005 10:51:29 PM GMT
Paul: That’s exactly what I intend to do, either take two pictures, or double expose one. Double exposure –or more precisely, single exposure, double flash- does have a good side effect of keeping image output half the size. During CCD processing, I might be able to compress the data stream as well. The complexity added to the image processing step by using a single image is negligible.
As far as rotation tracking, I’m hoping a thick (1-2 mm) black line around the circumference of the ball will be adequate for rotation analysis. I’m working right now with some test images with a single line. The first section of code is in place to cull the scene, but the ideas for rotation aren’t implemented yet. As long as the image quality is clear enough, finding the rotation won’t be very difficult with a single plane dissecting the ball. So, obviously the only concerns are source image(s) and speed.
For right now, I’m going to get a prototype camera trigger in place using a visible-light flash and see what I can get for image quality.
Once again, thanks for “bench racing” with me
- Hatter -
