The help file will tell you which commands require $PBASIC 2.5 syntax. In general, we recommend that you use 2.5 syntax as your default. We maintained the older 2.0 syntax for backward compatibility of older programs that may use 2.5 keywords as program labels.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Jon Williams Applications Engineer, Parallax
Dallas, TX· USA
DO WHILE, LOOP or UNTIL.
dont be confused with the version of the editor that you have which is 2.1, this is the most current.
the three options you can have are 1.0, 2.0, and 2.5· (second line after you state which stamp you are using)
DTQ
Jon Williams
Dallas, TX· USA
