Help With Homework Board Compatibility Issue
I have been working on trying to get the article written by Jon Williams in Nuts And Volts
to interface a ps2 controller for weeks ofcource to no avail.
I called parallax and
I try it without the 220's in the circuit and nothing happens!
But to get to the point, has anyone succesfully used a psx controller with a HomeWork Board? And if not... does anyone else know a way we could controll the robot
The robot is for Sience Olympiad's Robobilliards competion.
ps: I have used 2 different SONY DualSHOCK controllers
pss: The needed amount of buttoons are 4 drive buttons 6 arm buttons
Mitch Gaffigan
St. Pat's 7th Grade
DMT Data Management
HelpGuy said...
The Homework board has 220 ohm resistors in each of the outputs and may be causing the setup to malfunction
Mitch Gaffigan
St. Pat's 7th Grade
DMT Data Management
That article is popular today ... I spoke with a customer by phone who was also having trouble with that project. He contacted me later to tell me that he found a broken wire. I feel pretty confident in the circuit and code -- double-check your connections. And the 220-ohm resistors on the BOE are not the problem, I am quite certain of that.
Jon Williams
Dallas, TX· USA
Why are you using microcontrollers for the event?
The inversion transistor was producin a bad wave!
I got a ttl hex inverter and it worked perfectly
the microcontroller allows us to preprogram arm positions.
