Basic Stamp Removal
Stampers,
I have several BOEs and five different Stamps and have had the need to remove and replace Stamps on the BOEs. I use a small screw driver with a 90 degree bend on the end to gently pri the Stamp out of the socket. This has worked well with the Stamp (and other socketed ICs) and I have never bent a pin or damaged a chip. However the last time I removed a Stamp·I noticed there are some traces on the bottom of the Stamp board. I got to thinking that there might be·the possibility of damaging or scratching these traces with the screwdriver.·To prevent scratching the traces I placed a small piece of shrink tube on the end of the·screw driver·to prevent damage to the bottom of the board.
I have two projects that have ZIF sockets in them but don't have any of my BOEs (ones I had did not seem to fit very well).
Anyone else use a different method of Stamp removal?
Mike S.
Mike S.
Work:· Clemensb@otc.edu
Bolg: http://theDeadBug.journalspace.com
Sid Weaver
Do you have a Stamp Tester?
These work just fine on smaller DIPs, say under 14 and under pin count. But I've bent more pins using the cheapy tweezer style extractors than I have with any other technique. Maybe it's just me and others have better luck with them.
Jim
Sid Weaver
Mike S.
Johnny
Huh?
Do you mean that you put the stamp, or whatever chip, in a socket and then plug it into the socket on the PCB? I never thought about that, but it seems like it ought to work pretty nicely.
Jim
Johnny
You should learn one new thing each day. That's my thing for today. Now I can go back to bed.
Jim
Johnny,
Thanks for the post. I'll give it a try.
Mike S.
Thanks!
The important part about the screwdriver is to gentle pry each side a little at a time, working the chip up and out. I'm sure I'm stating the obvious, but, prying one side completely out, then the other, will result in bent and broken pins.
Jim
