controling using RF
I am a high school student learning to use a BS2.· I have operated a BOE Bot, and have basic knowledge of how to operate the stamp.· I have run into a problem, however.· I have two 433 MHz RF transcievers, and have sucessfully had them communicate to each other using a master/slave program I found using this site, but can not figure out how to put it to use (ie. blinking LEDs, operating a BOE Bot).· Are there any programs/literature available to download or purchase that would help me?· Thanks
You transmit from your Stamp:
serout pin, baud, [noparse][[/noparse]"a"]· You want the BoeBot to turn on an LED
pause 5000
serout pin, baud, [noparse][[/noparse]"b"]·· Turn LED off
The BoeBot receives via its receiver:
serin pin, baud, [noparse][[/noparse]com]
Then you write (on the BoeBot Stamp) -
if com = "a" then HIGH LED
if com = "b" then LOW LED
You can use any byte on your keyboard - number, letter, $, #, &, etc.
One thing to remember - watch your timing.· The BoeBot must be sitting at a serin before your master serouts.· If·the master·serouts, and the BoeBot isn't ready to serin, it will never see the serout, and will just sit and wait forever when it finally gets to its serin.
Sid Weaver
Do you have a Stamp Tester?
The program given did not quite work the way I expected it to.· The serout part went into one, but the serin kept asking for labels on the "HIGH LED/LOW LED" part, so I simply told it to goto·two programs for high/low·LED.· I am still unsure on what to do next.·
Here's how I modified the serin commands so it would actually download to the stamp:
c var word
serin 13,16468,[noparse][[/noparse]c]
if c = "a" then go
if c = "b" then no
go:
low 5
no:
high 5
serout looks like this:
serout 15,16468,[noparse][[/noparse]"a"]
pause 5000
serout 15,16468,[noparse][[/noparse]"b"]
Any elaboration would be greatly appreciated.
