Do I really need a resistor here?
In the "What is a Microcontroller?"(I think)·book it says to use a resistor when using a LED. I tried this and I couldn't see it light up. Do I need to use the resistor?
Thanks Michael
Thanks Michael
If you are using a 12V LED you won't see it no matter what.
Sid Weaver
Do you have a Stamp Tester?
Bean.
If you are using one of the What's a Microcontroller kits, those LEDs are standard. They do not have resistors built-in, and you will need a resistor to protect both the BASIC Stamp and the LED.
If your LED isn't emitting light, it may be plugged in backwards, or there may be some other circuit or programming error. Also, try a different LED. Defects are pretty few and far between, but if you are using LEDs that have unknown history, definitely try some others.
Take a closer look at the What's a Microcontroller text, it explains how current limiting resistors work and why they are used. It also explains how to determine which pin is connected to the LED's cathode and anode, which is crucial information for making the LED work on the first try.
The BASIC Stamp HomeWork board does have 220 ohm resistors between each pin on the microcontroller and the I/O pin socket you use. If you have a BASIC Stamp HomeWork Board, it's true that you can get away with a couple of LEDs with no resistors. Any more than two LEDs, and you will have to check the BASIC Stamp manual for maximum allowed current. Each LED with a resistor in series draws this much current: I = 3.4 V / R.
The BASIC Stamp Manual Version 2.1 is available for free download from www.parallax.com -> Downloads.
Post Edited (Andy Lindsay (Parallax)) : 1/17/2005 12:41:13 AM GMT
The sink/source current per I/O is 20mA or 30mA·depending on the Stamp you have. As long as your LEDs draw less than that you'll be ok.
http://home.cogeco.ca/~rpaisley4/LEDcalc.html
http://samengstrom.com/elec/resistor/5band.html
Green Gold Black Black Brown.
Any ideas?
Brown-Black-Black-Gold-Green [noparse]:)[/noparse]
10ohm, 0.5% according to the link
Black = 0
Brown = 1
Red = 2
Orange = 3
Yellow = 4
Green =·5
Blue = 6
Violet = 7
Grey = 8
White = 9
Gold = 5% tollerance
Silver = 10% tollerance
None·= 20% tollerance
First two numbers are leading digits, last number is power of 10 (or number of zeros). (For newer precision resistors you might get 4 color bands, 3 digits and power of 10).
Example: Yellow Violet Red··= 4· 7· * 10 ^ 2· = 4 7 * 1 0 0 = 4,700
How to remember? Use the politically incorrect catch phrase "Bad Boys Rape Our Young Girls, But Violet Gives Willingly. Get Some Now" That gives the 1st leters in order.
Now then, Brown Black Black is 10 ohms, that is too small for a LED.
The 220 ohms (Red Red Brown) previously suggested is a good value. If you don't have one, any distributer should have them, Radio Shack has em if you want them fast.
Boris I thought about swapping it over but the the big gap is in the wrong place. Also my multimeter gave me 0.675 on the 2K setting, Is this 675 ohms then?
Here is the way I was taught to remember it.
BAD······· ·Black = 0
BOYS·······Brown = 1
RACE······· Red = 2
OUR········ Orange = 3
YOUNG···· Yellow = 4
GIRLS······ Green =·5
BEHIND···· Blue = 6
VICTORY·· Violet = 7
GARDEN···· Grey = 8
WALLS····· White = 9
GET········· Gold = 5% tollerance
STARTED·· Silver = 10% tollerance
NOW········ None·= 20% tollerance
I learned this in the Navy 25 years ago and still remember it!
RWC
Russell Crow
Project Manager
Cohesive Automation Inc.
Here is the confusing part.· When the circuit is turned on I should be able to measure a voltage drop across the pull-up resistor.· Instead, I get zero volts across the resistor and 5 volts measured·between the top·and the bottom of the resistor·and ·Vss respectively.·· Its like the resistor is not even in the circuit.· I've checked to make sure connections a tight and even moved to alternate connection sites on the breadboard.· The resistor measures the correct resistance.· What am I missing?
Julian
