1 ohm to 2 ohm measurement
I am considering wrapping a nickel-chromium wire around a post for position feedback on the azimuth tracking of a solar dish. The variable resistance would range between something like 1 ohm to 2 ohms. How should I measure this?
Assuming 5VDC = 4.97 volts
Assuming 4.7K = 4790 ohms
Measure the voltage across the 4.7K.· Let's say it is 4.968.
4.968/4790 = .001037 amps
Measure the voltage drop across the nichrome.· Let's say it is .002 volts.
You know there is .001037 amps flowing in the circuit, so........
.002/.001037 = 1.98 ohms.
There measurements are imiginary but you get the idea.
Sid Weaver
Do you have a Stamp Tester?
Are there wires with much greater resistance or should I start over with a new idea such as incorporating a pot or memic 2125 tilted by a wire?
Also, the same idea can be used for elevation with a pendulum weight mounted on the shaft of the pot(s).
Martin
satalites use kepliarian elements which are updated continously and available. Amateur radio for years have used tracking system which are controlled by computer (using the keps) which feeds azmuth elevation to the az-el rotors. These systems are in use world wide currently.
73
spence
k4kep
