Halloween Project: Spooky Eyes in the Bushes
The intent of this simple project is to create random glowing eyes in the bushes.· When triggered, the program will select a random ouput and ramp up the brightness of the eyes (LEDs) connected to that pin using the PWM instruction.· The schematic shows an active-low input, but this can be easily adjusted in the program for an active-high input -- this would allow the project to be triggered with a small PIR motion sensor.
Applicable PIR sensor: http://www.hvwtech.com/pages/products_view.asp?ProductID=95
Jon Williams
Dallas, TX· USA
Post Edited (Jon Williams) : 1/16/2005 9:53:28 PM GMT
Jon Williams
Dallas, TX· USA
Do you have the program in PBASIC 2.5?
bugg
So many projects, so little time.
Okay ... it took all of two minutes to update the program for the BS2.· I've attached it to the original post.
Jon Williams
Dallas, TX· USA
Post Edited (Jon Williams) : 1/16/2005 9:51:17 PM GMT
bugg
Get some 1" clear acrylic spheres from your local plastics house or www.craftics.com.
Sand the surface of the spheres to eliminate internal reflection.
Drill a hole in each sphere - .199 dia by .30 deep - and epoxy the LEDs in the holes with clear epoxy. (hole size is for standard 5mm LED)
Mask off the outline of the eyes and iris with tape or opaque paint allowing light to emit only from the pupil and cornea.
Fabricate a mounting bracket. (acrylic is easily drilled and tapped)
Chris Isaacson
bugg
What is the V and mA ratings of the LED's?
Jon Williams
Dallas, TX· USA
thanks for the information.
