The BS2
MacGeek117
I have a few questions about this stuff, like what is the temperature range for
a stamp, what does stamp stand for, and do you think this program will work?
the IN4 and IN5 commands are for a pushbutton circuit that I have designed.
+ 5 VDC
IN5 --+ IN4--+ | |
bugg
So many projects, so little time.
+ 5 VDC
IN5 --+ IN4--+ | |
bugg
The Stamp name came from the observation (by then Parallax employee Lance) that the original BS1 board was about the same size and an international postage stamp. The early manuals used postage stamp graphics on the cover.
Jon Williams
Dallas, TX· USA
In regards to your temperature question, the range for the BS2 and varients is 0 to 70C.· There's an industrial version of the BS2 that'll go down to -40C (which I love and use a lot).
Hey Jon, any plans for an industrial BS2e,p, or sx?· I would definately eat those up.
Dave
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
www.parallax.com
Post Edited (Dave Andreae (Parallax)) : 1/15/2005 5:34:34 PM GMT
Sweet, why don't y'all have that advertised like you do the BS2 industrial?
Dave
pushbuttons connected to a common anode an connected to 2 different pins.
I'm using a Boe-Bot with tank treads.
Achilles03,
you would be able to have a Boe-Bot running outside in winter for short periods of time,
right?
bugg
Well, depends on what's a short period. 5 minutes? Probably ok. 50 minutes? Probably not. A BS2 industrial will ensure that the limiting factor wouldn't be the stamp, and it's only 5$ more than the regular stamp.
Also, according to sales ALL BS2sx's are industrial. I've been asked by more than a few people via email about the low temperature performance of the BS2 industrial cause of my project on the customer apps page. Y'all (Parallax) should probably update the BS2sx's information on the website, as some potential customers might not be biting because it lists (incorrectly) its lowest operating temperature as only 0C.
Dave
the time period would be more like 5 minutes.
bugg
Johnny
Dave
Anyhow, these guys worked and worked and worked....almost never changed in voltage and would work to down near -30degC where mercury will freeze (or change chemical composition--can't remember).
Anyhow, we used these to calibrate wind speed tachometers in the field.· Wind normally turns a small tachometer (generator) which creates a voltage....we replace that with a battery of known voltage so we can calibrate our displays that are 1km away.·
Steve
http://members.rogers.com/steve.brady
bugg
