No carrier board
Howdy all,
I have a bs2-ic and I would like to start programming / using it. I have no carrier board, and realize things would be much easier if I had one. However, due to time constraints and funding constraints I would like to use an alternative, before I go ahead and solder a wire onto each of the pins, just wonder if anyone has any ideas / suggestions that may help me?
Johnny
Johnny
See here on how to wire your carrier board http://www.parallax.com/detail.asp?product_id=27120
and see Jon Williams note about where to add the two .1uF caps http://forums.parallax.com/forums/default.aspx?f=5&m=59759
You'll also need a DB9 male to female, straight thru cable to connect your board to your computer's serial port.
Off to radio shack!
Johnny
