SEROUT using Binary
Hello again everyone.
So I have a coding question. I am sending data through the serial port on my Board of Education (BS 2). This data needs to be in a Binary format. I am going to copy and paste the relevant stuff below, in addition to my somewhat close attempt at this. Also, I am under the assumption from the notes that I can send this data out of the same serial port that my Board of Education uses to receive code. Am I correct? Thanks Everyone!
My attempt:
SEROUT 16, 19200, [noparse][[/noparse]BIN ? 0xBE + 0xEF + 0x03 + 0x06 + 0x00 + 0x2A + 0xD3 + 0x01 + 0x00 + 0x00 + 0x60 + 0x00 + 0x00]
Some relevant information about this code:
- This code will be used to power on / off an LCD projector. A person at Hitachi was nice enough to forward me some of this stuff
- 19,200 bps
- 8bits data length
- no parity
- 1 stop bit
I'll copy and paste the code that works through HyperTerminal
Sending RS232C Command Using HyperTerminal
1. There are three sample files for sending RS232C command to the projector.
HTC Projector.ht :
HyperTerminal file that defined communication settings. This is for COM1 port configuration. If you need to change the port, please configure the properity setting.
PowerOn.bin :
Projector sample command for “Power On”. The “Power On” command consists of 13 bytes binary data ( i.e. 0xBE + 0xEF + 0x03 + 0x06 + 0x00 + 0xBA + 0xD2 + 0x01 + 0x00 + 0x00 + 0x60 + 0x01 + 0x00 ).
PowerOff.bin :
Projector sample command for “Power Off”. The “Power Off” command consists of 13 bytes binary data ( i.e. 0xBE + 0xEF + 0x03 + 0x06 + 0x00 + 0x2A + 0xD3 + 0x01 + 0x00 + 0x00 + 0x60 + 0x00 + 0x00 ).
The binary command files will be sent directly via HyperTerminal as following steps.
2. Connect your conputer with the projector using the appropriate cable.
3. Double click the file named “HTC Projector.ht”. Make sure the communication settings are correct. It should be 19,200bps baud rete, 8bits date length, no parity and 1 stop bit.
4. Send a sample binary file to your projector. Select “Transfer text file” menu, the file dialog will appear. Please select the binary command file “PowerOn.bin” or “PowerOff.bin”. The projector will respond to the command immediatelly.
of what he sent me below... This works when run through HyperTerminal.
My attempt:
- 19,200 bps
- 8bits data length
- no parity
- 1 stop bit
HTC Projector.ht :
PowerOn.bin :
PowerOff.bin :
You've got the pinout right in your serout line but you have to use the proper "baud value" for the baudrate you want to use.· simply typing in 19200 isn't going to work.· If you're using the BS2 then you'll need to use 16416 for your baud value.
I'm honestly not sure about your output string.· not sure if they have to be separated by +'s or ,'s.
Steve
http://members.rogers.com/steve.brady
http://www.geocities.com/paulsopenstage
SEROUT Sio, Baud, [noparse][[/noparse]BIN 255]
actually transmits "11111111"
And Hex values in PBASIC don't use C notation -- where you're using 0xBE you should be using $BE
Jon Williams
Dallas, TX· USA
You are using port 16, which means you are using the built-in serial port, which means you MUST wire in both the TX AND RX pins insure you get a good RS-232 signal level.
And the 'Baud' parameter is actually a 'Baud Select' parameter. Probably you want 'Inverted' + 19200 baud, so it should be something like 16348. See the manual under SEROUT for all your options, and the correct values.
And yes, DO NOT use the 'BIN' modifier. The default output format of the BS2 IS 'binary' already. When you put in 'BIN', it actually converts your single byte binary value into a multi-byte text version.
So after everyone's comments, I went to the Baud Rate conversion table and came up with 16416 - ( INT(1,000,000 - 19,200) = 52 - 20 = 32 + 16384 (inverted polarity) = 16416. Also, I am using the Board of Education Rev. B. Using my multimeter, I confirmed that Pin2 of the Serial is connected to SOUT (or Pin 16, I think), and that Pin 5 on the serial is connected to the ground. So I think all is well with that. I can't attach the .bin file for people to read (security in the forum), but below is the point at which my code stands now (not working yet). Thanks for your help!
start:
PAUSE 10000
SEROUT 16, 16416, [noparse][[/noparse]$BE , $EF , $03 , $06 , $00 , $2A , $D3 , $01 , $00 , $00 , $60 , $01 , $00]
PAUSE 10000
GOTO start
You'll need to add a connection to Pin 3 of the DB-9 connector (connect to SIN). I assume your projector has a suitable TX signal? This is used by the BS2 RS232 circuit when it sends its signal on Pin 2.
