Power supply from an old 'puter
I have an old, gutted, Dell computer that I'd love to strip out its power supply to use as a 5V/12V bench power supply for my stamp projects.· Does anyone know if these·units are regulated?· And equally important, is there a way to override·an ATX power supply so it doesn't need the motherboard attached to it?
Thanks!
Post Edited (Nightrider7731) : 1/12/2005 7:57:42 AM GMT
Thanks!
I'm sure there are mods on the 'Net to be able to use it for a straight DC supply.
I'd imagine it involves a couple caps and a regulator.· Google it.
So far as the ATX....I think there's just an enable line from the motherboard.· google the pin out of an ATX connector.
Here's a couple quick links I found:
http://www.ts-consulting.net/ATXPS.HTM
http://www.powerstream.com/itx-atx-pinout.htm
One site said you just need to ground pin 14 to get it to turn on.
http://www.marcee.org/Articles/PCPowerSupply.htm
Anyhow, there's some sites out there!
Steve
http://members.rogers.com/steve.brady
http://www.geocities.com/paulsopenstage
G. Herzog in Taiwan
I would add some more caps for filtering. As they are used for computers, they will be fine for stamp circuits, just watch the amperage, as
I have low amperage fast blow fuses in line to my breadboard.
Thanks!
So, to properly regulate 12Vdc, you need 14 or 15volts going in.· I think you CAN find rail-to-rail type regulators, but they still need a little bit of overhead.
Of course, if you don't load the power supply properly, you'll find the voltage to be higher (similar to unloaded wallwarts~~12Vdc unloaded wall wart will be up near 20volts.).
Anyhow, MAYBE, and I've never tried this, if you don't load down the power supply too much, it'll allow you to put a regulator on the end to get your 12volts.
Of course, just using some good sized filter caps would probably work fine!· smaller component count too! haha
Steve
http://shop.store.yahoo.com/directron/1130282.html
MikeS
