using BS1 Serial Adapter
I see two marks on the adapter, the top pin has two arrows facing downwards, and the bottom pin has an A below it. How does it mount on the BS1 programming output? I see a VOS, PCO and a PCI for the programming inputs.
which tells you the order to connect.
http://www.parallax.com/dl/docs/prod/schem/bs1.pdf
DTQ
Jon Williams
Dallas, TX· USA
