Help Please
Hi
I set up my basic stamp 2 module and my computer can't find it. It says yes in the echo column but that's it.·Pin 2 - 5 is connected to a file transfer serial cable pins 2 - 5. On the last two pins of the module, the last one is connected to the red cable of a 9V battery snap and the last but 1 is connected to the black cable. I've tested the pin that outputs 5V and it is, so I know it's got power. Any ideas what the problem is? I'm thinking it's the cable.
Thanks Michael
Thanks Michael
Sid Weaver
Do you have a Stamp Tester?
Sid Weaver
If you are using the kind of file transfer cable that I suspect you are, it's wired like a null modem. That is to say, pins 2 and 3 are crossed internal to the cable:
Incorrect Correct
2- - 2 2---->2
\ / verses what it should be
3- -3 3---->3
Rx to Tx, Tx to Rx Rx to Rx, Tx to Tx
You need a cable that's wired straight-through with full pin correspondence on each end.
Pins 1-9 on one end go straight through to pins 1-9 on the other end with no crossings.
Bruce Bates
