Solder mask
Does anyone know of a company which sells solder masks, I am looking for generic masks like 100-TQPF, 52-QFP, 32-soj, etc. Im not looking for a custom pcb design mask, just a mask to align to a particular part on a pcb so I can get a uniform layer of solder paste on the pad so I can use my micro tip iron·without worrying of bridging pins using the solderball technique (I can do .65 with the solder ball technique but the .5 pitch parts will probably prove to be much more difficult.
Paul
Paul
they refer to the use of screen printing for the solder masking. Is this true? Is solder paste of the cosistency that can be pushed through standard silk mesh screen? If so I'm golden I've already got a silkscreen printing kit, all I need is to goto Pearl·down the street and pick up a new screen. Does anyone know of guidance on this issue, is solder paste caustic to either the screen or the resist? Is a special purpose resist required?
To apply solder paste on a board, as part of the assembly process, you'll need a solder paste stencil (commonly referred to as a stencil). They are always made from stainless steel cut with either a laser or chemical etching. If you google solder paste stencil, you'll find some manufacturers that make the small stencils. A stencil designed just to place 1 component os often called a rework stencil.
Chris Isaacson
Starman: I've found a few stencil service providers, however because of thier custom "one off" nature they are outside the price I am willing to pay. I was looking for prototype style mass produced one part per stencil product that I could individulally lay out and hand squegee a 1" to 2"·square area for a $20 per stencil price range. The best I can determine, there·is no such product. The closest found is http://www.stencilsunlimited.com/prototype_stencils.php·(thanks Jim)·but they make absolutely no mention of what is on the prototype stencil, and the $149.50 is outside of what I am willing to pay at this moment (I have some costs coming up wrt the SX contest and the stencil is low man on the totem pole).
Kramer: Thanks for the insight, but a multistep process is a little more than I am willing to undertake at this exact moment. I already have several new processes Im having to learn with this project, and I don't want to risk missing the deadline fiddling with a chemical process.
Thanks for everyone's input, if I win a prize in the contest I'll probably have a custom stencil·containing with every non-BGA surface mount footprint under the sun. Until then (or when I can afford it if I don't place) I'll get lots of rest and not drink coffee before attempting to solder
Paul
Paul, you're using the optimum soldering tip. The only thing I can think of to improve your fine pitch soldering is to possibly switch to a thicker flux. I've had success with a similar assembly process using a thin coat of Kester TSF-6821 (tacky flux, water soluable) brushed on the pads before soldering.
