Backing up a stamp?
I have the following situation, We used to have a small research lab at work which made us various custom devices. The organisation in it's wisdom shut the place down and made the staff redundant :-(. One of the devices used a Basic stamp 2p to talk to a GPS module. One of these has already been "blown up" by a user and so I would like to try and backup the object code from a working unit in case I need to make another. We don't·have the source code. I know the code can't be read directly from the PC (or can it?) But I was wondering if I could plant some code in bank 8 (assuming the original code isn't that big) without affecting the existing code, and use the READ command to dump the contents of the rest of the EEPROM to the PC. So the question basicly is can I plant code in bank 8 without overwriting the existing code? and if so how?
Cheers.
Martin.
Cheers.
Martin.
Anyway, if the bank contains any program code at all, it WILL be overwritten. If it 'only' contains data, it depends, as the new program will be loaded in the highest adresses and downwards. If the data is at the lower adresses they may survive...
It may be simpler to remove the EEPROM from the module and read it in an EPROM reader/burner.
(Maybe the EEPROM in the destroyed module can be salvaged?)
One way to make an adapter for these chips(adapters are VERY expensive) is to make a small PCB with tracks going in from the large .1" pin places of a 'normal' IC and in to the middle and where the SMT chip will fit. Then get hold of a strip of the conductive rubber strips used on LCDs and cut a couple of pieces and place them on the PCB. Then just drop the EEPROM onto the rubber strips and use a piece of transparent tape to hold it in place...
If the chip is aligned properly, it should work OK...
Don't have a burner?
Use another BS2...
Martin.
Martin.
In other words: 'why didn't I think of that?'
