Sharing OScope and BOE on same USB Port
The USB oscilloscope documentation says that it should be the only device on a root level USB port. I understand that the issue is current consumption. Is it acceptable to combine both the Oscope and BOE on the same port using a non-powered splitter? The schematics for the BOE show that the USB-Serial converter components draw their power from the USB port.
My dev platform is a laptop and one more cord would certainly not be a welcome addition.
Jim
Jim
The easist solution to this is an additional PC card in your laptop with one to four USB ports. Note you will drain your laptop battery faster this way. A 'clunky' solution is a powered USB hub -- but you lose portability this way.
If your laptop has two USB ports already, then one can be O'Scope and one BOE.
Well Belkin technical support begs to differ with you on that. Their statement was that there is no speed difference between powered and un-powered hubs. The only difference is that a root hub will provide up to 500ma to a device, where as an un-powered hub may provide as little as 100ma per device depending upon how many devices are placed upon it.
He made an interesting additional comment regarding hub speed. According to Belkin USB 1.1 hubs, of any form, provide anywhere from 1.5 - 2.5 mbit/sec throughput. And that while the 1.1 spec is for UP to 12 mbit/sec, they have no hubs in their product line that will come anywhere near that.
Now this is the statements of one tech support person at one company. But Belkin's products are pretty middle-of-the-road performance wise, so I would take this as indicative of consumer grade USB hubs as a whole.
On the other hand, the tech person could be all wet. That's been know to happen in this industry before.
Jim
Post Edited (Jim McCorison) : 1/7/2005 10:22:14 PM GMT
I have not had good luck, personally with the Belkin USB products.
·· For your info, USB 1.1 ports have a transfer rate of 12 Mbps/S, while USB 2.0 has a transfer rate of 480 Mbps/S.· As you can see (With a little math), USB 2.0 is 40 times faster.
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Designs Page:··· http://www.lightlink.com/dream/designs
http://www.everythingusb.com/usb2/faq.htm
It's quite informative!
Bob
Knight Designs
P.O. Box 97
(607) 535-6777
It should be pointed out that the USB speed is UP to 12 mbps/sec. Finding actual real genuine speeds of various devices is like finding hen's teeth. They all say they comply with USB 1.1, or USB 2.0, or some marketing buzzword that makes one sound like the other. But just try finding a published performance number.
Jim
·· As a computer technician of 20+ years, I can tell you from experience that when you're doing something like backing up data to a USB Drive, you can certainly see the difference...I remembed I copied some commercial clips I did for a friend's business onto one of my USB 2.0 160GB HDs...It took about 1 minute...When I took it over to his house we realized he didn't have USB 2.0!· It took 40 minutes to copy the same files...In terms of throughput that confirms the difference in tranfer rate difference between the 2 standards...So I will go out on a limb and say yes, I am using the full bandwidth in that sense.· I guess the same thing with our Thumb Drives...We are usually moving a few hundred MB at a time.
Knight Designs
P.O. Box 97
(607) 535-6777
Chris,
I was referring only to USB 1.1 devices. Yes, 2.0 is mucho faster. But my statement about USB 1.1 devices still stands. There is little if any real data published by the various manufacturers. It comes down to "buy it and see". They claim compliance with the spec, but that's it. I've not looked at any 2.0 devices, but I'd be surprised it it was any different. Expect it to be a lot faster, but don't have a 1.1 device on the chain, or the whole chain degrades to 1.1 performance.
Cheers,
Jim
· In the PC world it's a RARE thing that anything meets or compiles with a given spec!·
Your point is noted.
Knight Designs
P.O. Box 97
(607) 535-6777
That's where I find fun and enjoyment in the microcontroller / electronics world. The information is there for the asking. And there is more info than any one person could every assimilate.
Jim
So far, using the non-powered hub with the USB Scope and BOE has worked fine. I don't think I've really stressed either one yet, but working through the Understanding Signals course it has so far worked fine.
Jim
Also you don't need to worry about other devices using up bandwidth on the USB buss.· All the data is acquired in hardware and then when the buffer is full the data is sent up to the PC to be displayed.· Even at the fastest setting the Parallax Scope is only uses about 100Kbytes of the available bandwidth.
At the moment we are developing new software for the Parallax USB Oscilloscope and if any one is interested in beta testing software feel free to contact me.· Also please send any suggestions you may have for the new software.·
dpientak@parallax.com
Thanks for the input. I am only using the BOA and scope on the single port. It's been running just fine with no problems. Which given the power consumption you mentioned is not surprising.
Jim
