Drilling BASIC Stamp 2SX OEM Module
I have BASIC Stamp 2SX OEM Module, and i need to securely mount it in a project box. For some reason those who designed it did not predrill any mounting holes in the circuit board. In my project·the board is connected to another board with the RS232 port, but thats not enough support. I was wondering if its possible to drill a small hole in the top-left corner of the board (if the components are facing you, the RS232 port is on the bottom, and the all the pins are along the right edge). It does not look like there are any traces in that area, but I am not sure.
Is it safe to drill a small 1-2mm hole there?
My Current Project:
http://www.BulldogBot.com
I thought it was, just wanted to make sure.
Jon Williams
Dallas, TX· USA
My Current Project:
Or, you could just carefully drill the board...·
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Designs Page:··· http://www.lightlink.com/dream/designs
When drilling printed circuit boards, I find that if you use a pin vise with small drill bits, you get very accurate results and much better control.·
You usually can finish the project in the same time it takes to find and plug in the drill.·
And, you will not have those nasty accidental slips and wandering that happen with a power drill.
G. Herzog in Taiwan
Dave
The BS2, along with other compoenents is mouned in a 3x6x8,·plastic project box. This is for an industrial aplication, and i have to account for a posibilty of this box being dropped, etc...
That ought to protect it against just about anything...
I have a whole pile of plastic (obviously non-conductive) screws, nuts, and stand-offs. With the addition of a convienent hole or two, I can have something that can be removed or modified whenever I find I need to redesign or the project is no longer needed.
I also use the pin vise and drill for very small bits that tend to break. These bits can clear a solder filled hole on a circuit board when required or I can use the small bit to cut just one printed circuit wire when the need to modify and existing circuit is needed.
Try a pin vise and use will wonder why you ever thought use needed more.
G. Herzog in Taiwan
