WAM2.2 Servo Warning
                    In the Whats a microcontroller student guide v2.2 it states:
WARNING
Use only a 9 V battery when your Parallax Standard Servo is connected to the Board
of Education Rev B. Do not use any kind of DC supply or “battery replacer” that
plugs into an AC outlet. Improper use of these devices can cause the activity not to
work, or even permanently damage the servo.
I had been using a 6v regulated walwart power supply with the BOE USB reb B board without any problems with the servo.
In my application I want to use the servo without having to use a 9v battery.
Why the warning? What does " improper use of these devices" mean?
                            WARNING
For servos, follow the instructions for the BOE Rev C. Since you will be using a wall wart, just make sure to set the jumper as shown in Figure 4-5 on page 107. This will supply the servo with 5 V (Vdd), regulated by the BOE.
Thanks for the fast reply.
Functionally, what you have is the USB version of the Board of Education Rev C. This being the case, follow instructions for the Board of Education Rev C. This applies for the instructions in both What's a Microcontroller and Robotics with the Boe-Bot.
Since you will be using a wall wart, just make sure to set the jumper as shown in Figure 4-5 on page 107 (of What's a Microcontroller v2.2). The jumper makes it so that the servo is supplied with 5 V (Vdd), regulated by the Board of Education. So long as your 6 VDC supply is rated for 300 mA or more and has the correct plug, it should work just fine. Appendix D in What's a Microcontroller has more details along with some examples of proper vs. "improper" use.
There are two problems I was trying to prevent with that warning:
Sorry about the confusion. I wrote those warnings when we only had the serial Board of Education (BOE). Now we have USB BOEs. With the inconsistent revision letters, I can see some "who's on first, what's on second" confusion on the horizon.
Post Edited (Andy Lindsay) : 1/6/2005 4:30:20 AM GMT
