Driving a 120V solenoid (or two)
Disclaimer:· BS2 noob
I'm trying to prototype driving two 120V ASCO solenoids using a BS2.· Where would I go to find the specs on a transistor that could handle this load, or would this be better handled by a relay of some type?· Feel free to drop part #s for reference.
TIA
TIA
Jon Williams
Dallas, TX· USA
I have used Crydom·with good results, model # D2W203F and SDV2415.
Good Luck!
I use the Opto-22 OAC-5 and Grayhill Mini·modules to drive ASCO valves. The Grayhill number is 70M-OAC5
The small ASCO Valves (1 inch pipe and smaller) can be safely driven with these Modules. I actually drive 3 valves with one module.· The valves draw about 100-200 MA and the SS's are rated for 3 Amps. I never drive the SSR's more than 50% (1.5 amps). I have never had a failure with one yet. Some of my systems have 30 of these valves run from one Stamp.
Hope this helps you,
Alan Bradford
Plasma Technologies
TIA·
Usually the voltage rating is the maximum that the relay can handle. I will not say that is true 100% without knowing the type of SSR you are interested, but that is·what is typical. If you look at the spec sheet it will say the range (60-240 VAC or something·like that)
Alan Bradford
Plasma Technologies
TIA for all the valuable suggestions this forum provides!
Jon Williams
Dallas, TX· USA
