Communication Failure
I am a newbie to Basic stamp. I just got a BS2 for Christmas, and I have just tried my first basic circuit. I fear I may have fried it already.
I am using a breadboard to do my circuits and programming.
I have a 5V power regulator changing the 9V power suply before entering the BS2. I was unwittingly running the the power into the 5V out pin on the powere regulator, sending 9 V and some changin into the BS2. When trying to send my program to the BS2 in this state, it said it found no Basic Stamps. Once I realized what I was doing and sent the power in correctly (5V), the compiler program sees the BS2 but has a communication failure (it fails to download the program).
My home is someone out there that knows a lot about this can offer me a logical fix and tell me I did not just destroy my christmas present.
This leads me to guess that you're not using any sort of Parallax provided platform (board of education; etc..).
Did you follow the schematic for building around a stamp?
You should have a jumper across pins 7&6 on your programming port and also have a couple of capictors in there too!
http://www.parallax.com/dl/docs/prod/schem/bs2.pdf
this is the link to the schematic....you want to look at the "Host Serial Port Conneciton" part.
or look at this one too...same difference!
http://www.parallax.com/dl/docs/prod/schem/bs2revf.pdf
Steve
http://members.rogers.com/steve.brady
http://www.geocities.com/paulsopenstage
Physical Computing.
I am doing something very much like what is shown in this photo but without the capacitors for decoupling:
See some excerpts from the book I am following
Here is how I am trying to communicate with the BS2:
I have done some tests to check the power. I get 5V at pin 21 like I should be getting and I get 4.4V at pin 1 which I think is about right too.
How can I determine if the communication failure is from a burned up stamp and not from something else?
Post Edited (earthlingzed) : 1/4/2005 3:49:30 AM GMT
If you look at the 2nd link I gave you, the one cap goes from the ATN pin to ground.· This will help keep the pin from floating which, I believe, causes a reset on the stamp.·
Jon or allan will correct me!· Hopefully! [noparse]:D[/noparse]
Steve
Is there a way to determine if the stamp is blown? Is it even a posibility if I measured 9V going into the stamp (stamp was getting hot and the power regulator was also getting pretty hot).
Is there a way to determine if the serial connection is bad?
Post Edited (earthlingzed) : 1/4/2005 12:24:20 PM GMT
Now motors make even more noise than digital circuitry -- but they both need decoupling capacitors.
A meter might not give you exact readings, but would show a deflection when data goes out....like the engine light on the car (don't know what it means, but something is going on!).
The Stamp may be alright....get the power set up right and those caps and you'll be able to determine if your comms are cool!
Steve
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Designs Page:··· http://www.lightlink.com/dream/designs
But yes, put it in as well!
Steve
Did you intentionally blot out the stamp in the pictures you posted? If you're using a PicAx or other microcontroller similar to the BS2 (but not the BS2), then it might require a different setup to work properly.
Dave
As for the loopback test, that returning a fail message, but the echo works.
When I type in the debug window, the debug message is displayed below as well.
Can someone tell me if this is any indication that the serial connection is working?
Thanks everyone for your generous help!!
Jon Williams
Dallas, TX· USA
The echo is still giving me a positive response while the loopback test is failing.
I am lost and unsure what to try next.
The 'Echo' test verifies that the TX and RX signals are reaching the board, and being echoe'd back. I think this validates the RS-232 conversion circuit (4 transistors).
