Stepper experiment 26 of Stamp Works 1.2
I received an Errata sheet along with the above Stamp Works 1.2.· The sheet refers to a change in driver IC (from ULN2003 to ULN2803) as well as a changed stepper with different lead colors.
1. My NX-1000 board still has the ULN2003.· My guess·is this will work fine if I wire it right.
2. The supplied stepper has 6 leads (2 x Brown, red, white, orange and blue).· These colors don't match either the supplied manual experiment 26 or the errata sheet.
Suggestions will be appreciated.
Basic stamp Newbie
Basic stamp Newbie
I couldn't find one that has two brown wires, you'll need to most likely connect both brown wires together.··The ULN2803 and 2003 are the same except for the 2803 has an extra channel.·
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
www.parallax.com
Dave
Dave Andreae
Tech Support
www.parallax.com
That looks like exactly the information I need. I'll assume the code stays the same. If not, I'll bumble through.
Basic stamp Newbie
http://www.parallax.com/dl/docs/prod/motors/27964.pdf
Jon Williams
Dallas, TX· USA
Your document shows the lead color/phase relationship for the early Howard Industries stepper as well as the later Mitsumi. Dave's document shows lead colors that are representative of the stepper that actually came with my Stamp Works.
My first trial results in only vibrating the stepper so I'll have to dig a bit deeper to relate the Program to the variations of data that you and Dave have provided.
Thanks to both of you for a very prompt response!
Basic stamp Newbie
Jon Williams
Dallas, TX· USA
If you are unable to use this stepper motor please contact us at 1-888-997-8267 and ask for "Tech Support" or our "Sales Department" and we will replace the stepper motor with the correct version.· If you have any more questions please feel free to contact me at dandreae@parallax.com.
Dave
Dave Andreae
Tech Support
www.parallax.com
Thanks for your support!
I switched the phase leads around until I got it to work. When I get a chance, I'll post the lead color/terminal combination that worked for me in case someone else has a problem.
Basic stamp Newbie
