RC input to Basic Stamp
I am trying to send a signal from a RC receiver·to·input pin 6 on a BS2 and have the BS2 send out a hobby servo signal. The purpose for this is so I can control the servo speed with Model airplane RC unit, but if the BS2 circuit detects an object, it will take control of the servo movement. To start with I am just trying to get the BS2 to repeat the RC signal.
Now here is what I have done. The RC receiver gets its power from the BOE, therefore both the receiver and BS2 have a common ground. The Pulse signal from the RC receiver is connected to pin 6 on BOE. The signal ground from the RC receiver is connect to the BOE Vss.
Here is the code-
' {$STAMP BS2}
' {$PBASIC 2.5}
' RC input to Basic Stamp for output to hobby servo
ch1 VAR Word··· 'time of pulse received from RC receiver
cycle VAR Bit·· 'cycle counter
main:
··· PULSIN 6, 1, ch1··· 'signal from RC receiver
··· DEBUG DEC ch1,CR··· 'show value of ch1
··· GOSUB forward······ 'go to sub "forward"
·· forward:············ 'sub "forward"
··· FOR cycle = 1 TO 5
····· PULSOUT 12, ch1·· 'pulseout pulse of time value "ch1" on pin 12 (servo)
····· PAUSE 20········· 'pause 20 ms
··· NEXT
··· GOTO main
My problem is that the BS2 only passes the first signal it gets, no matter how the RC input is changed. I think it is in my code. Any help will be greatly appreciated.
Joe Fishback
Here is the code-
' {$STAMP BS2}
' {$PBASIC 2.5}
main:
··· NEXT
··· GOTO main
Joe Fishback
You were DARNED CLOSE. Try the following which is a slight modification of your coding:
' {$STAMP BS2}
' {$PBASIC 2.5}
ch1 VAR Word 'time of pulse received from RC receiver
cycle VAR Nib 'cycle counter
main:
PULSIN 6, 1, ch1 'signal from RC receiver
DEBUG DEC ch1,CR 'show value of ch1
GOSUB forward 'go to sub "forward"
GOTO main
forward: 'sub "forward"
FOR cycle = 1 TO 5
PULSOUT 12, ch1 'pulseout pulse of time value "ch1" on pin 12 (servo)
PAUSE 20 'pause 20 ms
NEXT
RETURN
END
Bruce Bates
First of all, you've committed a cardinal sin of programming. You've mixed GOSUBS and GOTOs.
<code>
GOSUB label:
<code>
END
label:
<code>
RETURN
When the GOSUB is executed a return address is pushed onto a stack. When a RETURN is encountered, this address is popped back off the satck, and execution branches back to the instruction that follows it. If you intermingle GOTOs and GOSUBS you can have the situuation where you return to someplace other than what you intended. For example:
<code>
GOSUB Do_Some_Stuff ' Do_Some_Stuff is pushed on the stack
<code>
END
Do_Some_stuff:
GOSUB label1: ' label1: is now pushed on the stack
label 2:
<code>
GOSUB label3: ' label3: is now pushed on the stack
RETURN ' the stack is now popped, but label1: is returned and execution goes there, not after Do_Some_Stuff
label1:
<CODE>
GOTO label2 ' Note GOTO, not RETURN. This will bite you!
label3:
<CODE>
RETURN ' the stack is now popped and label3: is returned, execution proceeds after that GOSUB
I'm not sure if this helps clear the issue of mixing the two styles. If not, please ask further. It is an important concept to understand.
Jim
Thanks alot, I now see what I did wrong and interstand it.
With that little change and alittle more code, I now have both wheels of my BOE-BOT robot controlled by RC. Also the Ir and bumper sensors over take control from the RC if an object is detected.
Joe Fishback
