Probably not -- what you may want to do is some sort of buffer/driver like the ULN2003/ULN2803.· The attached schematic shows one line connection.· The 330 resistor is based on putting about 20 mA through the LEDs.· At 1.5 volts each, there is 6 volts across the resistor.· 6 / 0.020 = 300, 330 is the closest "standard" value; this results in 18 mA through the LEDs.· The resistor should be 1/4 watt (0.018 x 6 = 0.108 x 2 = 0.216, hence 1/4 w).
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Jon Williams Applications Engineer, Parallax
Dallas, TX· USA
Post Edited (Jon Williams) : 1/3/2005 5:37:01 AM GMT
My assumption was that he would animate several sets of LEDs to get attention, hence my choice of a multi-stage driver. I showed just one stage for simplicity.
Dallas, TX· USA
Thanks for this post....after reading the nuts and volts article on the uln2803 and spending a couple hours trying to figure out why I could not get an led to flash your image said it all.· The article had pin 10 listed as a + supply.· When trying to run it this way (as a current source I suppose) it just would not work.·· Using it according to your diagram (current sink??) it works perfectly.· I guess I should have searched the forum earlier.· Lesson learned.·Now I have to rewire my 8-bit relay board to use the chip properly!
Jon Williams
Dallas, TX· USA
Martin Hebel
Electronic Systems Technologies
Southern Illinois University Carbondale
Personal Links - ·Lot of BASIC Stamp info
and
SelmaWare Solutions
StampPlot Pro Version 3 Release 4
Graphical Data Acquisition for your Micro and Imagination!
Now allows additional controls to be added, or developed.
Jon Williams
Dallas, TX· USA
Heating up the iron,
Chemania
