Ir Help
I can't figure out whats wrong, Please help.
' Homemade IR Remote
' Device Settings
DEVICE········· SX28, OSC4MHZ, TURBO, STACKX, OPTIONX
FREQ··········· 4_000_000
' IO Pins
IrLED······ VAR···· RA.0
' Constants
start_bit ·con ·1
stop_bit ·con ·4
bin_0 ··con ·2
IrMod··CON·38000···' modulation freq = 38 kHz
bin_1 ··con ·3
between_pulses ·con ·2
counter ·var ·byte
IR_message ·var ·byte
duration ·var ·byte
' Interrupt
IR_message = 25
· PROGRAM Start
'stop
' Program Code
Start:
Main:
freqout IrLED, IrMod, start_bit
pause between_pulses
for counter = 0 to 7
duration = 2 + IR_message.lowbit(counter)
freqout IRLED,IrMod,duration
next
freqout IRLED,IrMod,stop_bit
goto Main
Curtis
' Device Settings
' IO Pins
' Constants
start_bit ·con ·1
stop_bit ·con ·4
bin_0 ··con ·2
bin_1 ··con ·3
counter ·var ·byte
duration ·var ·byte
' Interrupt
IR_message = 25
· PROGRAM Start
'stop
' Program Code
Start:
Main:
next
goto Main
Curtis
You can isolate the bit like this:
Send_IR_Msg: temp1 = __PARAM1 ' copy of message FOR idx = 0 TO 7 ' send 8 bits temp2 = temp1 & $01 ' get bit 0 temp2 = temp2 + 2 ' add zero timing GOSUB Ir_Modulate, temp2 ' module temp1 = temp1 >> 1 ' shift bits right GOSUB Delay, 2, 1 ' inter-bit delay NEXT RETURN IR_Modulate: temp3 = __PARAM1 FREQOUT IrPin, IrFreq, temp3 RETURN Delay: temp4 = __PARAM1 temp5 = __PARAM2 PAUSE temp4 * temp5 RETURNI've busted things into subroutines to help you conserve program space.
Jon Williams
Dallas, TX· USA
temp2=2 + temp1.0
instead of
temp2=temp1 & $01
temp2=temp2 + 2
It is legal to add a bit to a bytevar.
Bean.
