93LC56B/P Serial EEPROM
I try write/read data to 93LC56B/P chip. It is 128x16 bit organization EEPROM with 3-wire serial interface.
Eveything shows good until I press BOEs reset. Then reread chip and some data are changed.
Can anyone help?
Thanks, Tommi
My test program:
' {$STAMP BS2sx}
' {$PBASIC 2.5}
' BOE Rev B, BS2SX v1.0, 93LC56B/P EEPROM 128x16
' CS (1) --> P11 CLK (2) --> P12
' Din (3) --> P13 Dout (4) --> P14
' Vss (5) --> Vss NC (6)
' NC (7) Vcc (8) --> Vdd
CS CON 11
CLK CON 12
Din CON 13
Dout CON 14
Pse CON 5 'Delay for pauses
TstDta CON $1111 'Test data, easy chance
Addr VAR Byte
Dta VAR Word
DtaHi VAR Dta.HIGHBYTE
DtaLo VAR Dta.LOWBYTE
Tmp VAR Bit
main:
DEBUG CLS
Addr = $00 'Read data from specified address $00
GOSUB RdRom
IF Dta <> TstDta THEN
DEBUG "Data from address $00: ", HEX4 Dta,CR
DEBUG "Write ",HEX4 TstDta, " into all address $00-$7F",CR
GOSUB EwenRom 'Enable Erase/Write EWEN
FOR Addr = $00 TO $7F
Dta = TstDta
GOSUB WrtRom 'Write data into specified address
NEXT
GOSUB EwdsRom 'Disable Erase/Write EWDS
ENDIF
GOSUB RdRom 'Read data from specified address
DEBUG HEX2 Addr," ", HEX4 Dta,CR
NEXT
END
EwenRom: 'Erase/Write Enable EWEN
HIGH CS
PAUSE Pse
SHIFTOUT Din, CLK, MSBFIRST, [noparse][[/noparse]%10011\5, 0\6]
LOW CS
PAUSE Pse
RETURN
EwdsRom: 'Erase/Write Disable EWDS
HIGH CS
PAUSE Pse
SHIFTOUT Din, CLK, MSBFIRST, [noparse][[/noparse]%10000\5, 0\6]
LOW CS
PAUSE Pse
RETURN
WrtRom: 'Write data into specified address
HIGH CS
PAUSE Pse
SHIFTOUT Din, CLK, MSBFIRST, [noparse][[/noparse]%101\3, Addr, DtaHi, DtaLo]
LOW CS
PAUSE Pse
RETURN
'Read data into specified address
RdRom:
HIGH CS
PAUSE Pse
SHIFTOUT Din, CLK, MSBFIRST, [noparse][[/noparse]%110\3, Addr]
SHIFTIN Dout, CLK, MSBPRE, [noparse][[/noparse]Tmp\1, DtaHi, DtaLo]
LOW CS
PAUSE Pse
RETURN
Can anyone help?
Thanks, Tommi
My test program:
' {$STAMP BS2sx}
' {$PBASIC 2.5}
CS CON 11
CLK CON 12
Din CON 13
Dout CON 14
Addr VAR Byte
Dta VAR Word
Tmp VAR Bit
main:
DEBUG CLS
GOSUB RdRom
Dta = TstDta
NEXT
ENDIF
NEXT
END
HIGH CS
PAUSE Pse
LOW CS
PAUSE Pse
RETURN
HIGH CS
PAUSE Pse
LOW CS
PAUSE Pse
RETURN
HIGH CS
PAUSE Pse
LOW CS
PAUSE Pse
RETURN
RdRom:
HIGH CS
PAUSE Pse
LOW CS
PAUSE Pse
RETURN
