Question about updating variables thru 2x16 LCD and 4 button keypad
I'm completely new to BASIC Stamp and I'm about to start a project with a BS2 (or BS2P). The project is going to be a very flexible phototrap. User interface will be a 2x16 LCD and four button keypad. Part of it will let the user select one of a set of up to 4 variables (delay_before_firing, rearm_time, etc. Each variable will be three decimal digits. It must be a fairly common task to select a variable, display it on line 1 and then use RIGHT, UP and DOWN arrow buttons to pick a digit on line 2 ( or end of line 1) and increase or decrease it ? Is there any super elegant code out there already to do that ?
While I'm about it, which is best to get started with - BS2 or BS2P ? BS2P is obviously (?) faster and has more code space and is easier to interface to lcds. On the other hand, my time critical code will only be about 4 or 5 lines looking for two HIGH inputs and then branching to a subroutine to actually control the delay, fire and recharge, the BS2 uses less power, most of my code will probably be the user interface hence the original question [noparse]:)[/noparse]
Thanks in advance for any suggestions, examples, etc.
The LCD stuff is easy -- just takes a bit a patience.
Jon Williams
Dallas Office
LCD stuff - yup, I figured it wasn't really that hard, haven't written any code for about 15 years but I figure it's just a question of selecting a particular bit from the word and working on it. I was just being lazy really, or perhaps trying not to invent a wheel [noparse]:)[/noparse]
Andrew
