Javelin Connection
Trying to get the Jav to boot first time EVER. Think power is O.K. -- using an ordinary 10 V DC PS -- green LED comes on -- but the IDE test sequence doesn't seem to be able to reset the board. Any particular requirements for the power other than between 6 and 24 VDC?
Post Edited By Moderator (Jon Williams) : 12/29/2004 2:23:28 AM GMT
Luckily I inspected the board before plugging it in (as I normally do!).
I think the punched hole throws people off in so far as marking pin 1 (even though in the wrong orientation it still doesn't mark pin 1)....
Anyhow, as I've found when getting brand new equipment at work, check all connectors and such for proper fits....got burned once, and so far, that's all it took! [noparse];)[/noparse]
Steve
http://members.rogers.com/steve.brady
http://www.geocities.com/paulsopenstage
