Compact, low BAUD, RF TX/RX plans?
Does anyone have any circuits·for a low BAUD (~20)·RF TX/RX·that is very compact and reliable? Size, reliability, and cost·is more important that speed.· I'd like to get some stamps to·talk to each other. I don't·need much bandwidth, so I figured I could get·away with some "made from scratch"·circuits.·More crude the better.·
TIA,
TIA,
You may be distance limited -- I haven't done a lab to show what the max distance you can get over just a wire. In any event, for a little bit more you can put RS485 Transciever chips to get 4000' distance between boards.
If you are trying to 'roll-your-own' you may quickly run foul of the FCC interference rules. The nice thing of the off-the-shelf units is they are FCC approved (bandwidth, interference, distance, and RF power limits).
Which raises the question, "How much distance do you need?"· If you're in the same room, IR communication could be enough.
www.hometown.aol.com/newzed/index.htm
www.hometown.aol.com/newzed/index.html
Klaus
STUDY THE SYNTAX IN THE BOTTOM 32 CHARACTERS IN THE ASCII CODE PROTOCAL. THEY GIVE YOU THE BASICS FOR ONE WAY TURN AROUND TO ALLOUW MANY PEER TO PEER UNITS TO COMMUNICATE ON A SIMPLEX FREQUENCY.
IE
THIS IS #5,HALLO #1 ARE YOU THERE
THIS IS #1, RGR #5 i AM READY FOR TRAFFIC GO AHEAD
TRAFFIC, ( END OR MORE TO FOLLOW)
RGR GOT IT
THATS ALL END OF WORK
OPEN NOW FOR ANOTHER INITIATE.
73 SPENCE
K4KEP
73
spence
Thanks again.
