Palm Pilot infrared port
I got a Sony Clie Palm Pilot that has an infrared port.· Does anyone know how to use the port or program it to output different pulses to communicate with a stamp?·
I know it can be done somehow, Ive heard of people programming them to output a pulse that matches that of the infrared emitters in slot machines so that they can trick the machine into thinking no coins are coming out.
You can do two things.
First, I think the Sony Clie has a program that allows you to make it function as an IR remote control [noparse][[/noparse]similar to a TV remote control]. You can use this interface and program a BasicStamp2p to recognize the code.
Second, there is a nice inexpensive C program that you can buy for less than $20US. It is called Pocket C. It will allow you to write your own custom IR interface so that you don't have to interpolate TV channels to commands.
I don't know about IR on slot machines, but if you are in Las Vegas or Nevada, they say the desert is full of bodies. They are a tough crowd to tangle with. It ain't worth it.
G. Herzog in Taiwan
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
www.parallax.com
www.parallax.com/detail.asp?product_id=30070
Jim
