Hexcrawler RC Question
Looking at the wiring for the Hexcrawler RC system, using the Tower Hobbies 6 channel RC controller.
Wanted to clarify the wiring from the output of the receiver, to the BOE.
2 outputs (channels)·go to pins on the BOE. Knowing that this would be the signal lead, but unsure from there. I assume I want to tie common back to the common side of the 14.4V battery supply, but what about the hot side? Since I'm not plugging a servo direct to the receiver, and the 14.4 powers the servos, I'm not sure what to do with that power pin.
Am I correct in the assumption that I am just using ground and signal here, and leaving +V, from the receiver via the servo connector, unconnected?
