ohm's law? — Parallax Forums
ohm's law?
mizemize Posts: 15
edited 2004-12-24 13:02 in General Discussion
if you have a power supply outputing 10 volts and you want to decrease this to 5 volts how do you determine what size resistor to use?
  • BeanBean Posts: 8,129
    edited 2004-12-24 01:36
    You need to know how much current the circuit will draw @ 5volts.
    Bean.
  • steve_bsteve_b Posts: 1,563
    edited 2004-12-24 02:25
    Is it a power supply that's giving you 10V or a wall wart?·
    Just note that an unloaded wall wart will have a higher voltage than what's printed on it for specs.· You need to connect circuitry (a rated lamp would work) to bring it under proper load and measure it properly.· It's akin to wave jumping in boats.· The boat is going at 40mph @ 2500RPM...well, as soon as you launch off that first wave on the wake, you go airborne and the propellor is no longer under load so the RPM's go WAY up (redlining if you're unlucky!).· This is the best I have for an anology.
    Anyhow, I'll assume you are looking to run a stamp.· If you're only after the stamp to be powered with minimal circuitry (no add-ons) then you're looking at about 10mA.· (I don't have the stamp specs in front of me, but I think that'd be sufficient).·
    With 10Volts as your main supply, you want it halved...so you need a voltage divider consisting of 2 resistors of the same value.· This will half the supply....to keep about 10mA of current you'll want to use 2 500ohm resistors.
    here's the Calculation:· E=IR;· R = E/I = 10/0.01 = 1000ohms.· This is the total divider resistance needed for the current.· Now, divide this by 2 (500ohms) and you got your resistors.
    You just connect it like this:
    +----VVV---|----VVV----<>
    10V··500R··· 5V···· 500R··· Gnd
    Hope that's clear enough....
    Steve
    http://members.rogers.com/steve.brady
    http://www.geocities.com/paulsopenstage
    edited 2004-12-24 05:31
    The best resistor for this is called a "voltage regulator". It is a resistor that uses feedback to adjust its resistance to exactly the correct value to get 5 volts output, no matter what the input voltage or output current (within limits!)
    +10 volts Vin ----resistor
    load
    ground
    I
    5 = 10 - I*R
    R = (Vin - 5) / I
    R in ohms, V in volts, I in amps
    Tracy Allen
    www.emesystems.com
  • mizemize Posts: 15
    thanks for the info. i can work it out now.
