problem with boe board, please help!!!
I was having problems with my BOE board, and I·thought you guys might be able to help me.
Just so you know, I'm running Windows XP Pro, BOE revision B, and BS2.
My BOE w/ BS2 has been working fine since today.· I plug in the batteries and the power ligh comes on.· When I click on the identify button, it finds it, but when I try to download programs, it doesn't see it.· I tried the troubleshooting that the manual suggests which involves unchecking the FIFO buffers box.· It has been working just fine until today.· I have not run any circuits on it today or done much with it at all.· Please help me.
Thank you,
Jason
Unreal tournament 2004 rox
Post Edited (DestroyerX) : 12/23/2004 9:17:06 PM GMT
Thank you,
Jason
What 'Batteries' are you using? As I recall, the BOE has a plug for a 9-volt, but that's about it.
This can be a low battery, or a mis-plugged serial cable. Or, using the 'wrong' (a 'null-modem' or 'not straight-through') cable.
Did you unplug and plug back in your BS2? If you were off a pin, maybe you could see this.
My PC is recognizing the BS2, it just can't download. What do you think is my problem?
Thanks for your help,
Hopefully you guys can help me get my BOE back workin.
Jason
Post Edited (DestroyerX) : 12/24/2004 1:27:08 AM GMT
I don't know if that's the problem. I tried a brand new 9 volt battery and it didn't work. Also, I've been using a 5 volt input for almost two years w/o any problems. My board just stopped working today.
Post Edited (DestroyerX) : 12/24/2004 3:53:52 AM GMT
Jon Williams
Dallas Office
Jason
Jason
The fuse (500ma) is there to primarily protect the amp meter on low scale measurements.
It may also protect the ohm meter.
Usually, the voltmeter is high impedance and can protect itself as long as the range is higher than the voltage.
You may also notice that the HIGH amp meter says 'unprotected'.· Even on a Fluke, you can burn you your meter by misuse of the high amp meter.· And, you can do some serious injury to yourself [noparse][[/noparse]burns].
Replace your fuse and start over as your thinking has gotten sidetracked and the conclusions your are drawing are based on muddled information. I often get into similar straits from overwork or too much coffee.· Technical solutions need a clear mind.
G. Herzog in Taiwan
Post Edited (Kramer) : 12/26/2004 1:49:48 PM GMT
-bugg
As I said before, my PC recognizes the board and also says there is loopback. What do you think my problem is? Since my PC is seeing the module and says there's loopback, does this mean my module isn't burned out? Or what is my problem?
DestroyerX
For Vin, I got ~6.13 V
For Vdd, I got ~.81 V
For Rst, I got ~32.6 mV
Are these measurements right?
What is the problem with my BS2 or BOE?
Jason
Jon Williams
Dallas, TX· USA
When I took my measurements, I attached the test leads to pins on the BS2, not the board. Is that where I should be testing?
Sorry, but I don't know too much about the BOE bot.
If I did measure the right place, what could account for such a low reading and my BOE suddenly stop working?
Jason
Post Edited (DestroyerX) : 1/2/2005 4:01:44 PM GMT
