I pretty new at this... I've had a stamp for 4 days. But I am also wrestling with a similiar question. For the device I am trying to design I'm thinking of using Bluetooth for communication, but my range requirements are fairly short.
A lot will depend on what hardware and comm lines you have at the remote location. If you have a unix box (Linux, or whatever) you could hook up pin1 of the basic stamp, which is serial out, to a comm port. Then have a process that just sucks in whatever is feed to it and stuff it into an file. You'd need to devise a format for the data so that the you could predictable create the desired file. This file could either be an html file or a text file depending on your needs / desires. If the remote box was running a web server, you'd be able to display it directly via the server. Otherwise you'd need to ftp it to the target web server on a periodic basis. Lot's of different ways to accomplish this based upon the specific requirements.
These are my rough thoughts. I sure that others with way more experience with stamps will show me the error in my ways.
Jim
Post Edited (Jim McCorison) : 12/27/2004 2:45:13 AM GMT
Just so you don't lead yourself astray, any pin port on the Stamp can be used for SERIN/SEROUT. It is suggested that you use an inline resister to prevent any possible overcurrent damage to the pin port, when using other than the DEBUG port. The DEBUG statement is nothing but a specialized SERIN/SEROUT.
Problem is It will be installed in the boonies, I am lucky to have Dial tone. There is no way to get DSL there, unless I want to use satallite....That One web site just dosen't have Dial up....Maybe someone else can help...
Well you didn't mention what you had available to transport the web pages. If you have a phone line why don’t you use the modem that parallax sells. http://www.parallax.com/detail.asp?product_id=603-00011 I haven't used one yet but I think it will work for what you’re trying to do. Check out the app kit download, they have a remote project in there.
Jim
Bruce Bates
Thanks again for your help
Guido
how far is remote and what country are you in? Can you use frs radio? Is it allowed where you are?
73
spence
k4kep
