Demonstrating the R-2R Resistor Analog to Digital converter
Write a program to produce a number of different waveforms through the D/A converter. The waveforms will include:
1)················ triangle wave······························ 2)·· Positive ramp sawtooth
3)················ Negative ramp sawtooth··········· 4)·· Square wave
Begin with any waveform you wish and use a normally open pushbutton to step through the 4 different waveforms and then start back at the first one again. The frequency of the waveform is not important and it does not have to be variable. Apply the D/A Vout to an oscilloscope that has been set to the appropriate input voltage level and horizontal sweep rate to view the waveforms.
The LCD will still be connected to the Stamp in 4-bit mode. Each time the normally open button is pressed and a new waveform is produced, the LCD will simply display the title of the waveform type being outputted.
ok I dont know any thing about A/D converters, anywhere that I can look to find out about it?
Jon Williams
Dallas Office
Post Edited (Andy Lindsay) : 12/22/2004 6:44:00 AM GMT
