power
Hi
My project requires several peripheral to interface with the Javelin, all of which require power. Connecting them all to the carrier board's power suply takes the system too much. I even made my own external power supply with a 5v voltage regulator and synced its ground with the Javelin's ground. This worked for awhile, but this too has failed. Does anyone have any ideas about how I can make a small but reliable power supply?
~Jiggs
~Jiggs
How many peripherals are you connecting?· Check your regulator specs on what it's max current output is and then check the draw on all yer add-ons.
If your add-ons' draw outweighs your regulators supply, then look at some of the bigger amperage regulators (2 or 3 A).
I'm not sure you need to tie the grounds together on the two systems.....BUT, you would with the comm lines going between the units.· Not sure how you're reading their data.·
Anyhow, I'd examine why it failed before putting another one on.·
Steve
http://members.rogers.com/steve.brady
http://www.geocities.com/paulsopenstage
~Jiggs
What was the 2nd regulator cct you built?· the same regulator IC?
Steve
Here are the current ratings for each device mentioned:
SFR04:· 30~ to 50mA~
Memsic:· less than 4mA~
Transceiver:· 20mA~
Parallax Servo:· 250mA~ no torque and 1000mA~ at full torque
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
www.parallax.com
You still didn't mention what regulator you used.· But I'll assume it's something similar to what the BOE is using.
I have the LM2940 on mine; this regulator will only do 1A.· So if you only have these in stock, you'll probably want to use a totally separate one for your servo.
An LM340A will give you 2.4A peak.· Here's the sheet.
I don't know, off hand, any other ones, but a search at any manufacturers website will get ya going!
Google it or go to Digikey
Steve
~Jiggs
I'd be VERY surprised if that 1A is there continuous at full servo speed....but certainly you could expect a fraction of it to be there....at least half if not 3/4's.· Just a guess!· But you're batteries definately don't put out 1A continuous....they wouldn't last long at all.
And just doing a quick look at the LM2940, it certainly is a 1A regulator.
Like most ratings of components, you should design your circuits to a 60% level.· So if you're working with 12Volts, you're caps should at least be around 20volts.· So if you're playing with 2A's worth of toys and don't expect to add more current hogs, then you might want to be sure you have 3.2A worth of overhead.
Doing a quick look on the digikey site, you might want to look at a TPS75501 which is an adjustable 5A LDO Regulator in a TO-220 package.· BUT, it's $8.80Canadian! haha·· It gets pricey....so if you have a few LM2940's laying around, then divide and conquer!!· Use a separate LM2940 for your servo's.
Just a thought!
Steve
