Multiple MCP23016 Questions...
I'm currently drawing up a card to hold the mcp23016 and some optos and triacs.· I have jumpers for the address lines and wish to be able to stack multiples of these cards together.· Also I want to tie the interrupt pins together and feed them into a BS2p using the polling features.
I have·few questions
1.· Can the interrupt pins be tied together and put on a BS I/O pin·directly?· Pull-up required? (each mcp is divided into 8 inputs 8 outputs)
2. Address pins.· Must they be pulled low or high, or will low and not·connected (floating) work?
3. SCL & SDA· One set of pull-up resistors (4.7k) needed per I2C buss.· Or does each device need them.· I assume just one set, right?
2. No, high or low -- do not let them float.
3. Just one set of pull-ups; usually on the "master" side of the circuit.
Jon Williams
Dallas Office
