I have to be some kind of idiot.. But I need help....
Ok, got the kit.. Got the code on the chip, it runs, it works, im happy....· It works great on the project board..· Everything is going great...
I go to install it, hard wire it...
I used a battery clip off of a 9v into a +5V Fixed-Voltage Regulator 7805 that I got at radio shack....
Run the ground to the battery clip...
Hook up my switch, output wire, and LED....
NOTHING :-/· I put it back into the bread board.. it works great..
Is there an entire part of hooking these things up i missed???
Probably not as easy as I thought it would be:-(
-X
-X
Jon Williams
Dallas Office
-X
Bean.
Nate
Also, I have a PIC16F#### And it is regulated at 5V also, should a +5 pin be strong enough to power the SX? When I hook up my multimeter it reads 5v straight, when I hook up the SX it for some reason drops to 2...
-X
Jon Williams
Dallas Office
Like Could i run RA.1 to a VDD and MCLR and have the chip turn on? (For Example)
-X
Bean.
+5 up to VDD
Ground up to VSS
and a +5 up to MCLR
and my program is
Main:
High RA.0
goto main
I never get any reading on the RA.0 pin!?
-X
and specify "FREQ 4_000_000"
You don't have MCLR on a different +5 supply do you ?
If none of this works, please post the WHOLE program.
Terry
