PWM "chip"
A member of the DPRG (Dallas Personal Robotics Group) was looking for a single chip PWM device that would take the duty cycle from an-eight bit bus.· Another member suggested an Atmel controller, of course I suggested the SX.· As an exercise, I wrote the attached program.· I tested it, and it works as expected.
Jon Williams
Dallas Office
Jon Williams
Dallas Office
Or how about some simple assembler:·5 bytes for the PWM routine, and 24 bytes for initializing the SX28.
id 'DACout'···································;Dec 16, 2004
device·sx28,osc4Mhz,turbo,stackx····;new assembler
reset·reset_entry··························;JUMP to start label on reset
roption·······equ·· %1000_1000········;RTCC rollover interrupt
intconstant·equ·· -40···················· ;10 usec base tick is 40 instructions at 4Mhz
··············· org···· 8
counter····· ds····· 1·······················;duty cycle accumulator
············· ··org··· ·0
interrupt···· mov·· w,RB···················;get external duty cycle value of 1 through 255
················add··· counter,w············;add duty value to one byte counter which then sets/clears carry depending on overflow
············· ··rl······ RA····················· ;pull carry into PWM output bit RA.0, other bits are irrelevant
················mov·· w,#intconstant·····;get rtcc time adjustment
············· ··retiw························ ··;exit interrupt with time adjustment
reset_entry································· ·;Program starts here on power-up and on reset.
initialize···· mov·· m,#$0d················ ;Set 0 for CMOS levels
···············mov· ·!ra,#%0000·········· ;cmos
···· ······· ··mov· ·!rb,#%0000_0000···;cmos
········· ·····mov· ·!rc,#%0000_0000···;cmos
···· ······· ··mov· ·m,#$0e············· ···;Set 0 for pullups
········· ·· ··mov· ·!ra,#%0001···········;
·············· mov·· !rb,#%0000_0000···;eigth bit parallel input
···· ··········mov· ·!rc,#%0000_0000···;port not used
········· ·· ··mov· ·m,#$0f············· ···;Set 0 for output
·············· mov· ·!ra,#%1110·········· ;bit 0 is PWM output
···· ······· ··mov· ·!rb,#%1111_1111···;eigth bit parallel input
········· ·· ··mov· ·!rc,#%1111_1111···;port not used
······· ······ mov· ·!option,#roption··· ·;1=RTCC, 0=enabl, 0=internl
main········ jmp·· ·main····················;sit here and wait for a rtcc overflow interrupt
This works great too, and certainly tighter code.
Peter
Jon Williams
Dallas Office
If constant frequency output is your goal, then you are correct.
However, if you intend to use RA.0 as the driver for an RC filter (say 4K7 into 0.1·uF)·to generate the DAC voltage, then this technique is superior as it generally has a higher output frequency more easily filtered by the RC.
I use this technique a lot, and by·using look-up·fixed increment sine amplitude values from a table for the DUTY value, it makes great looking sine waves.
In fact, if you run two sine waves of the same frequency simultaneously from the same processor, but shifted by a fixed (phase) period, and add them together, you can alter the amplitude by altering the phase shift. A real neat way to digitally generate modem frequencies with adjustable amplitude for 6 cents' wort of components (over top of the SX ofcourse). This really works!
If there is interest expressed in this, I'd be happy to post a schematic and (assembler) code for the sine generator.
Have fun experimenting all!
Peter
Jon Williams
Dallas Office
Jon, That parallel value comming into your program... is that from a PC printer port or some other parallel interface?
James Newton, Host of SXList.com
james@sxlist.com 1-619-652-0593 fax:1-208-279-8767
SX FAQ / Code / Tutorials / Documentation:
http://www.sxlist.com Pick faster!
Jon Williams
Dallas Office
