Control 120V AC Outlet with BS1?
Hi all!
Complete newbie here [noparse]:)[/noparse] Certainly willing to do my own research, but I'm not having a whole lot of luck finding any info.
I have one very simple question:
Can a basic Stamp 1 be used to simplpy turn on or off a 120 V AC outlet? If so, could anyone simply point me in a good direction to do some studying and research. i certainly won't ask anyone to spell out step by step instructions [noparse]:)[/noparse]
Thanks in advance,
/gb
Thanks in advance,
/gb
Sid Weaver
4 digit serial LED
Thanks for the quick reply! Did a little snooping, found several descriptions of controlling firecrackers with a basic stamp. That gives me a great place to start my project.
Thanks again!
/gb
CAUTION is always advised when working with mains voltages, and you should ALWAYS make sure there is NO POWER to the circuit when working on it.· That said, it's a common way to switch mains voltages.
If you have any doubt as to your ability to do it, I would stick with Sid's suggestion, since it's safer.
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Designs Page:··· http://www.lightlink.com/dream/designs
I'm really not sure where I fall here. *heh* have a significant amount of electronics, programming, and electrical project experience, but have NEVER played with a Stam,p or SSR...I'm guessing "first Stamp project" probably isn't the right time to start "first SSR project" as well [noparse];)[/noparse]
Other than a concern about how much current the X-10's will handle (One device I'll be switching draws a fair amount...haven't checked yet to know exactly how much) which I'll obviously have to research, I think Sid's idea is going to work very nicely...and even let the device be wireless. [noparse]:)[/noparse]
As I do more research, and form up a plan, I'm sure you guys will hear from me again [noparse]:)[/noparse]
Thanks again to both of you for the quick responses and ideas.
/gb
Al Williams
AWC
http://www.awce.com
The problem with SSR is that you should or
I should say MUST install a circuit breaker or a fuse in the 120AC LINE as a saftey precaution.
The SSR usually fails in a short circuit mode. This may become a fire hazard.
And the SSR has difficulty with certain devices upseting its internal electronics (such as fluroent lams due to high voltage transformers)
In sum, both the X-10 and the SSRs are solid state devices and have switching limitations created by the internal workings of solid state switching of 120VAC.
Alternatively, you can simply drive a +5 or +12VDC relay via a Darlington transistor (which is properly protected by a flyback diode). This simple solution results in you having a mechanical relay which is most likely to fail into an OFF mode. Thus, you have less of a fire hazard.
Much as purists would love to go solid state all the way, the relay is quite useful and will be around for a long time. Especially when you you want to build something that you can leave unattended.
G. Herzog in Taiwan
1. Please don't hijack posts from December 2004.
2. Please only post your USB solution (USBWhiz) once. Not on every single USB related post.
Thanks.
