SX-KEY v3.0 IDE Hangs
william chan
I don't know why nobody is complaining about this, but my SX-Key v3.0 and v2.02 both hangs frequently after programming the
SX Chips. ( using assembly).
This happens mostly in Windows XP machines, and more frequently if the IRC_CAL_4MHZ option is used.
Usually, the progress bar stops progressing, and then the dialog that shows you the nearest freq selected does not pop up.
Then the progress bar suddenly goes to the end, but the progress dialog stays.
But the SX Chip does get programmed correctly.
When this happens, I need to "End Task" the IDE program and then start again.
I don't mind if it happens 5% of the time, but it happens 45% of the time.
Two of my WinXP machines have the same problem, but one more doesn't.
I had thought that v3.0 would have solved this, but ...
Anybody, please help.
William
William
