Sx Compiler — Parallax Forums
Sx Compiler
CenlasoftCenlasoft Posts: 265
edited 2004-12-06 03:27 in General Discussion
I have several BSII project that I want to use an sx. I have an SxTech board and several sx 28s. On the compiler is it possible to use serout or something like count and pulsin or pulsout at the same time. I read that these commands were time sensitive and that asm would have to be used.
Curtis
    edited 2004-12-06 00:30
    No, and yes.
    No, you can't use the built-in commands and do two (or more) things at once. But ... you could create an interrupt-driven routines (VPs) that would let you do several things at once. This is not for the faint-of-heart, but it can be done.
    Jon Williams
    Dallas Office
  • BeanBean Posts: 8,129
    If you post more detail, we can probably tell you if it's "do-able".
    Alot can be done with interrupts, depending on what the clock speed is.
    Bean.
