Polarity Protection?
I have read various articles on this, from using reed relay/diode combos, thermistors and other circuit designs. Also, with my setup, i am using a dual power supply, 5v logic and 12v to motor. I have fried one motor control board already by accidently wiring the board wrong, and would like to make sure it doesn't happen again. So, i am really looking for a dual purpose protection, one for polarity protection of the electronics, and secondly over-voltage protection from bonehead mistakes from myself. Just wondering if anyone has an easy solution to this, even in the form of a complete component.
Thanks Kelvin
Thanks Kelvin
The circuit that uses a relay will turn on an LED if you connect the positive and negative wires with reverse polarity.
ken
The reason I mention this is because you need the voltage regulation and because all diodes waste 0.6 to 0.7volts.
If you use the discrete diodes for polarity protection, you have to supply a higher voltage and this power is just disapated in heat.
If you use a low drop out voltage regulator, you can consume that power in the microcontroller.
G. Herzog in Taiwan
